7 members (GMCJammer51, Youngin' Tut 59, Tim Canfield, jmoore, 3B, 2 invisible), 111 guests, and 1 robot.
Topics128,196
Posts1,057,385
Members48,469
ANY SUGGESTIONS ABOUT EITHER STAYING WITH BIAS PLY TIRES OR UPGRADING RIMS AT www.wheelvintique.com AND GOING WITH RADIAL TIRES?
CURRENTLY RUNNING:7.00 x 15 6-ply standard bias-ply Goodyears
IT SAYS ON TIRE CHART 3/4 TON 3600 7.50-17 8 LUG 6.5" CIRCLE
ON A 1 TON 3800 7.00-18 OR 7.50-18 8 LUG 4.56" CENTER
SHOULD I STAY WITH CURRENT TIRE SIZE OR GET LARGER?
Mike [email protected] 609-698-8706
Apprentice
Apprentice
Radial tires make a world of difference in drivablity, no doubt about that. Bias make it feel like your steering has more play in it than it actually does ( I dont need more than I have already!) My two cents worth.
I have been delighted with the change in driveability in my '40 since the change to radials.
I had 700x15 and went to 750R16 on Landcruiser rims on the back and 700R15 on the original rims on the front.
The rears are mud terrains , cause I need them where I go.
The truck steers easier and tracks straighter and has less rolling resistance (better mpg) smile
ODSS President
ODSS President
Get some popcorn as there are strong feelings on both sides... I'm a daily driver only vehicle, original rims with rubber as noted in signature, 45 K miles, no problems, highway speeds every day.
~ Cosmo
1949 Chevy Half Ton
