11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,347 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | Posted this over at inliners but no response yet...Looking to upgrade the single Rochester to a dual carb set up on my stock 65 C10. I had initially thought of using a Clifford 4 barrel manifold with a 390 cfm carb. I ran 2 Carter W1`s on my 55 pickup and found the response off idle to be lacking. What would be a good pair of carbs to run on a stock 230 with a split exhaust? Which manifold would be recommended?
1955 Chevy 3100
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Have you considered running a single 2 bbl on an adapter to your stock intake manifold. It would be an easier hook up I think. Tom Langdon has the set up on his store site. But, if you're definitely set on the 2 1bbl set up,I'd still use the W-1's with maybe a rejet up 2 steps from whatever you have in them now. I'd use an Offy intake for the 230. You might even find one in the Summit catalogue.
Drew
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | If you still have the dual Carter W-1's, you might consider retrying these.
Chances are either the adjustment was wrong, or some of the linkage was worn. These normally give excellent results.
Give me a call at 573-392-7378 (9-4 Mon-Wed central time); and I will be happy to describe what to look for.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | Thanks carbking and will talk to you when I get back to that stage. Would you reccomend the 574S?
1955 Chevy 3100
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | A pair of 574s Carters should work very well.
