7 members (latroca52, Hanks custodian, Jon G, BC59, 55shaker, Hotrod Lincoln, Shaffer's1950),
65
Mod | | | Forums66 Topics128,185 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | has anybody every swoped out a 1/2 ton rear end and put in a 3/4 ton rear end on there 3100 series truck. ive got a guy that has offered to give me a 3/4 rear end out of a 54 or 55 chevy or gmc, not sure which. it would be the open drive line then. it is the axe and pumpkin, springs and drive shaft. I know it would be 8 lug but i can deal with that. will it swap ok. the problem with mine is i need a new tranny and i have 3 4 speeds sitting around. i've got the 3:90 ratio in the rear not sure what the 3/4 ton is. might be 4:10. i'm needing new or different leaf springs on mine as it sits to low in the rear even with out anything it it. the heavier leaves would help if mine are shot. what do you think. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | The 3/4 rear is most likely 4.57 or possibly 5.14. Very slim chance it's 4.10, only if someone swapped in a late 60's early 70's unit. You don't say what year your truck is.
| | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | my truck is a 54 chevy 3100
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Probably not your best option.
The brake drums have been hard to get though apparently the 3/4-ton ones are now being reproduced.
The 4.57 gears will limit your highway speed.
You should be able to find another axle that is a better choice if you are committed to a change. It sounds like you're changing the rear because you need to change the transmission. An open drive type SM420 can be converted to torque tube type easily and that might be your most direct solution.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | You could use the pumpkin from a 55-59 chevy 1/2 ton with your axle, and get the open driveline. Of course there is some welding involved, but you would be doing that anyway. | | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | how do i convert and open drive type sm420 to a torque tube? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Change the tail housing. I've not done it, but know a guy who did. All he did was unbolt parts from one and bolt them on the other.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | I just had a guy call me a couple days ago and said he had a 4 speed with the tail housing out of a 50 or 51 about 10 miles from me. he said it was in good shape when he pulled it. what do i need to look for when i'm looking inside it. what might need to be replaced if anything from sitting. hope to get over to look at it this afternoon if the snow lets up. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Be sure to get the 4-speed's u-joint and keep your 3-speed's u-joint. You'll need to use the appropriate yoke from each one.
| | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | and if i can't get the u-joint where do i get one? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I think I got mine from Bruce Bugay in Glen Allen, VA 23059 Phone 804-752-6036 bwbugay@aol.com | | |
