| | | Forums66 Topics128,154 Posts1,056,855 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | What's the difference between a dana 70, 70hd, and a dana 80? I also wanted to know what I would have to do to get a 10 lug on 7.25" bolt circle for the above mentioned axles? I want the axle to be the wide dually axle because I want to build a fleetside dually pickup. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | 70 is a 70, usually has 3.5" axle tubes 70HD is like a 70, uses the same gears, but with larger carrier bearings, 4" axle tubes, and spindles sized more like a Dana 80 80 is an 80, bigger then either 70 or 70HD. I've been told that the 10 lug hubs for a 70HD won't interchange with an 80. I think a search of this forum will reveal the details, I forget exactly. I've never seen a 70 with the 10 lug hubs. On a completely different note. You were looking for folding steps earlier, here they are: https://www.surpluscenter.com/item.asp?UID=2468021821383980&item=1-3297&catname=Grigg | | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | So which would be the wider one or do I need to widen an axle housing and axles? I want this vehicle to handle a 478 GMC v-6, Fso-6406a trans, and pull around 22,000 on a gooseneck trailer. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | As far as I know (which is not very well) each can be had in two if not more different widths. Just take a tape measure with you on your searches.
A 3500HD with the 70HD or 80 is pretty narrow. Many P30 chassis with a 70HD are narrow. I expect some P30 chassis with 70HD or 80 are wide, look for one with tires out to about the edge of the body. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I have a 70-HD that is more than 70 inches wide. Might be 72 inches though I've not measured it in a couple of years. It is huge and it is heavy.
That rear came out from under a 70's GM Diesel dually, or at least that is what I was told by the guy I got it from. It is 8-lugs and has 4.11 gears.
I've also committed to trade it to someone else for something I want so if you want to ask questions about it do it soon, it should be gone in a few days.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
