0 members (), 177 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
What's the difference between a dana 70, 70hd, and a dana 80? I also wanted to know what I would have to do to get a 10 lug on 7.25" bolt circle for the above mentioned axles? I want the axle to be the wide dually axle because I want to build a fleetside dually pickup.
70 is a 70, usually has 3.5" axle tubes
70HD is like a 70, uses the same gears, but with larger carrier bearings, 4" axle tubes, and spindles sized more like a Dana 80
80 is an 80, bigger then either 70 or 70HD.
I've been told that the 10 lug hubs for a 70HD won't interchange with an 80. I think a search of this forum will reveal the details, I forget exactly.
I've never seen a 70 with the 10 lug hubs.
On a completely different note.
You were looking for folding steps earlier, here they are: https://www.surpluscenter.com/item.asp?UID=2468021821383980&item=1-3297&catname=
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
So which would be the wider one or do I need to widen an axle housing and axles? I want this vehicle to handle a 478 GMC v-6, Fso-6406a trans, and pull around 22,000 on a gooseneck trailer.
As far as I know (which is not very well) each can be had in two if not more different widths.
Just take a tape measure with you on your searches.
A 3500HD with the 70HD or 80 is pretty narrow.
Many P30 chassis with a 70HD are narrow.
I expect some P30 chassis with 70HD or 80 are wide, look for one with tires out to about the edge of the body.
---All pictures---
I have a 70-HD that is more than 70 inches wide. Might be 72 inches though I've not measured it in a couple of years. It is huge and it is heavy.
That rear came out from under a 70's GM Diesel dually, or at least that is what I was told by the guy I got it from. It is 8-lugs and has 4.11 gears.
I've also committed to trade it to someone else for something I want so if you want to ask questions about it do it soon, it should be gone in a few days.
