| | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 34 | converted to twelve volt.installed coil with built in resistor, get power to coil but nothing to cap.tried two different coil wires, same result. anybody? | | | | | Joined: Feb 2010 Posts: 28 New Guy | | New Guy Joined: Feb 2010 Posts: 28 | I assume you still have points? If so I would start with new points and condenser. I have seen condensers go bad for no apparent reason at the most inconvienient times. The points may be burnt or oxidized. If you have power to the coil then somethings amiss with points/condenser | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Continuity tester is extremely useful tool! VOM works, too! If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | Use a test light, and attach the pigtail wire to a known good ground such as the engine block, etc. Touch the probe to the distributor side of the coil primary. (Usually the - terminal). With the points open, the light should burn. As soon as the points close, the light goes out. If the light burns all the time, you've got dirty points, wrong point gap, a broken primary wire, or some other reason the voltage isn't getting to the points. If it's off all the time, points open or closed, you've got a short to ground somewhere between the coil and the points. The light should flicker on and off as the engine is cranked if you probe the distributor side of the coil with the test light. Jerry
| | | | | Joined: Dec 2006 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 34 | thanks to your tips i got it running, nice and rough. the firing order is correct.it is popping back through the carb. how do i know if i am a tooth off, advanced or retarted? thanks to all who answered! | | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | Pull the valve cover, and watch the #6 valves. Turn the engine by hand until the exhaust valve (last one in line) opens fully and starts to close. As the intake (2nd. from the back) starts to open, the distributor rotor should point right at the #1 plug tower. If you're a tooth off, either reset the distributor or just turn the whole housing to align it properly. The points should just barely open as you turn the dizzy counterclockwise with the rotor lined up with #1 wire and the pointer and ball on the flywheel aligned. Jerry
