12 members (Paul_WNC, Wally / Montana, Woodcmiami, Joe H, baldeagle, tonyt, DannyW, Bill Hanlon, walter74, gswbbc, lumbersawyer, 1 invisible), 94 guests, and 2 robots.
Topics128,040
Posts1,055,475
Members48,424
#621106 02/18/2010 10:08 AM
JRE
Offline
Ive got a 65 cab and 62 Frame and was wondering if the the cab mounts where the same on both or if they where in different locations for the two years.
JRE #621124 02/18/2010 12:53 PM
The 62 frame is wider than the 65. You can mount the 65 cab on the 62 frame but you have to drill new holes for the cab mount bolts.
1963 C10
JRE
Offline
Thanks. my truck was givin to me by my cousin. I noticed there was a extra hole in the front mount. Do I need to re drill the rear mount also.
As mentioned above, the '60-'62 frames are wider, than the '63-'66 frames, so it is not a direct swap, but it can be done. Before doing any cutting or drilling, set the '65 cab on the '62 frame to determine alignment, geometry and level. If you like the specifics, assess the cab mount frame perches, to determine if and what needs to be modified.
I hope this information is helpful and keep us posted on your progress.
