3 members (Joe H, Gdads51, UtahYork), 99 guests, and 2 robots.
Topics128,264
Posts1,058,355
Members48,485
#621054 02/18/2010 3:44 AM
when the timing marks are lined up on the crank and cam gears should the timing needle on the bellhousing line up with the ball or the triangle on the flywheel ? 58' 235
neswes #621075 02/18/2010 4:59 AM
The ball is the timing mark and the triangle is TDC.
Edit: From the links Tim posted below it appears I had it backward. It is now correct.
Cletis #621083 02/18/2010 5:19 AM
tclederman #621116 02/18/2010 11:23 AM
I agree TC that the triangle is Top dead center. But I was wondering where the 2 dots on the crank and cam gear should be at that point. Do they come together there or when the pointer is lined up at the ball. I don't have the truck here right now , it is in the body shop. This is one of those things that wake me up in the middle of the night when trying to solve my timing issues.
neswes #621123 02/18/2010 12:41 PM
on my 59 the it lined up with U/C and i also found out that its TDC on #6 not #1 as i thought.
51 ashton #621127 02/18/2010 1:08 PM
#1 and # 6 are always in the same position. I think what you mean is that #6 is on compression?
1951 1 Ton Completed
truckernix #621132 02/18/2010 1:38 PM
correcto ulmundo, thats what i meant to say.
51 ashton #621284 02/19/2010 12:46 AM
yes I understand #6 is on the top of the compression stroke when the gear timing marks are lined up but what is pointing at the needle on the bell housing -----The ball or the triangle
