2 members (Kilted54, UtahYork), 72 guests, and 2 robots.
Topics128,196
Posts1,057,392
Members48,469
1 Offline
my 62 is running 3.73 in the rear end and hit freeway speed alright, but is humming pretty good...
anyone gone from 3.73 to 3.55? is there much of a difference?
There are RPM calculators on the web that will tell you what your rpm is for a given rear axle ratio and tire size. Here's one there are others;
http://www.csgnetwork.com/multirpmcalc.html
I went from 4.56 to 3.73 in my 68 C20 with 327. I wanted to be under 2500 rpm at 65 mph, and 3.73 doesn't do it. A 3.55 would just get me there, 3.30 would be better. My tire size is 265/75 16.
Hope that helps.
Larry
I don't own a vehicle that isn't old enough to drink.
I went from 3.73 to 3.42 in the Dana 44. I'm very happy with it.
I've also got a 4spd manual OD trans, and it skips down the highway at 80mph effortlessly.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
I have a 64 3/4 ton GMC pu , I went from 4.10 to 3.53 gears and droped from about 3300 rpm's to about 2600-2700 rpm's at about 65-70mph. the truck has a dana 60 with 235-85-16 tires.Hope this helps mikie
