| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 8 New Guy | | New Guy Joined: Dec 2009 Posts: 8 | hey guys. tried looking thru past threads for my answers,but no luck. first when did 12 volt systems start? i looked on truck, no luck. the coil actually says 6/12volt on it!i put a 1958 chevy 235 in my first series 55 gmc.the chevy and gmc had the exact same 4-speed open drive line trans.2nd if its 6v,i have a 1940 starter from a 1 1/2 ton that bolts in, but will the gears match? 3rd, i found a hei distributer in a late 70s inline 6. will it fit the older moter to convert to 12? thanks for any help | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | 12V systems became standard on most vehicles in 1956.
I can't help on the coil question except to say if it was on a '58 engine it is probably a 12V coil.
A 6V starter will not mesh with a '58 12V flywheel.
The HEI distributor will not fit in a 235 but can be modified to fit. A search should locate the way it's done. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Chevrolet went to 12 volt in 1955, second series on trucks.
See the USA in your vintage Chevrolet! My Blog | | |
