1 members (2-Ton),
167
Mod | | | Forums66 Topics128,088 Posts1,056,114 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | I'm sure this is going to be a dumb question, but I just can't figure this out. I got a oil pressure line + fittings at NAPA, part # 701-2154. It comes with the fittings and 6ft of copper line. How in the heck do I get the fittings to fit on the ends of the lines?? They slide onto the line, but a little bit of force and they come right off! I assumed the nuts were compression nuts and would hold the fittings on, but they don't. What am I missing here? Heres a picture of the offender: http://i45.tinypic.com/5b5hdu.jpg | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | it's a compression fitting. there should be another piece that screws into the block and then that piece of copper with the nut and compression fitting screw into. when you tighten them they will seal.If you don't like that one get a 1/8 ferrule from the hardware store and use it instead of the fitting you have pictured.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you need a standard compression sleeve for 1/8" tubing, NAPA WH 60X2 should work. As Tommy indicated, these should also be available at any good hardware store. | | |
