2 members (78buckshot, IHPWR),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 51 | This is probably something I should know but I don't. My 53 truck has a 54 235. While fitting an air cleaner , I noticed my carb. measures 2 5/8" across the top. The one barrel aftermarket aircleaner was 2 1/4". So are there 2 sizes of one barrels for these engines?
[url=http://www.stovebolt.com/gallery/shannon_joe_1953.html]1953 Chevy 3100[/ur When life looks like easy street there is danger at your door
| | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | there are even different carbs. you either have a Rochester B or a Carter YF (or a very slight chance on some oddball thing). which air cleaner did you get? one specifically listed for this engine, from one of the classic chevy parts vendors? I don't have my books here to look up sizes, but start checking which carb you have. the factory put a B on it | | | | | Joined: Sep 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 51 | It's a rochester. I bought the air cleaner from the truckshop of orange California. The catalog said 1 barreel, so I assumed it would fit mine. Mistake, a simple mearsurement was in order. Oh well, Never had a problem with the stock carb so not thinking of any changes
