1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#619286 02/12/2010 7:56 PM
Couldn't find anything in my search here.
I've been catalog shopping for rear end gears (Jegs, Summit) and now have questions about the venerable 12-bolt truck rear. Seems there are "3-series" and "4-series" carriers, each with a different range of gear ratios available. The overlap appears to be 3.73:1, with lower ratios for the 3-series and higher for the 4-series.
Questions:
How do you tell the difference, if you've got 3.73?
Are they interchangeable in the same housing?
It's a '65 C10, and it seems easier to swap the carrier than the whole assembly.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Bump...anybody?
1965 Chevy C10
3B Offline
Hy starfire4, yes the two carriers will fit into the same housing. I seem to remember when we changed ratios in those rear ends sometimes we had to use a spacer plate between the crown [ring] gear and the carrier, probably the spacer plate was duplicating the dimensions of the other carrier. I don't know how to tell the difference between the two carriers, but I would imagine they would have some kind of identifying number on them.
Thanx, 3B.
cm
1965 Chevy C10
