| | | Forums66 Topics128,186 Posts1,057,308 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 13 New Guy | | New Guy Joined: Feb 2002 Posts: 13 | I have this heater in my 1952 truck.
I just converted to 12 volt, and I need a replacement for this 6 Volt blower to 12 Volt. Any suggestion for source?
Rolf
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you get a parts man to help you out, they have a catalog that lists all the motors by dementions & direction of rotation. You can use a resister on your 6 volt motor or I've just run them on 12 volts. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | All of the parts vendors sell them.Here are a few to pick from. jim carter classic parts of america lmc 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2002 Posts: 13 New Guy | | New Guy Joined: Feb 2002 Posts: 13 | Tim, thanks, I did not think the 6 volt was the same size as the 12 volt, I was just over-thinking the whole thing.
Thanks for taking the time to reply.
Cheers,
Rolf
| | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | The motor for the pictured heater needs the 1/4" shaft, not the 5/16. Your fan needs that size. If the vendor doesn't state the size you better ask. Chuck | | | | | Joined: Jan 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 77 | When I bought a new motor from Classic for mine it came with the adaptor for the shaft size difference. | | | | | Joined: Feb 2002 Posts: 13 New Guy | | New Guy Joined: Feb 2002 Posts: 13 | Thanks guys. I ordered one from Classic and they said that I have to drill out the fan shaft hole to 5/16" I should have it tomorrow.
I also drilled a hole on top of the heater housing, and installed resistors from a Toyota, so now I will have three speeds.
Rolf
| | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I returned a 5/16" shaft motor for a 1/4" because it did not look like the fan mounting device would have enough meat to keep the fan attached if drilled out. Maybe it will work well for you but there is not much there to begin with. Chuck | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | There are some 12v motors that have a 1/4" shaft with a sleeve that equals 5/16" .You basically need to ask questions.The other half is 5/16" shaft on the motor. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Don't throw out the option of rebuilding yours. If there's no short in windings or trashed insulation, the motor should serve its purpose. In a motor that unimportant, you can even patch repair a short or crummy insulation.
Dave
| | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I am not sure if these numbers are still good. I pulled the information from an old post. Grainger has what you need in a 12 volt motor / direct replacement. (12DC Perm Mag Motor Item #2M197) $15.81. I did a search and the item comes up discontinued. The replacement is 42.00 or so http://www.grainger.com/Grainger/items/3LCH7 It has a 1/4" shaft it looks like.
| | | | | Joined: Feb 2002 Posts: 13 New Guy | | New Guy Joined: Feb 2002 Posts: 13 | Sorry for late reply, and thanks for all the advise.
I did end up drilling my fan, the only thing was that the fan came loose off the hub. No big deal, I just tacked it back, evenly, to keep it balanced, and it works OK.
I added a Toyota 3 speed switch and resistor, and installed it in the housing just like late model cars, the top speed is way to fast and loud.
I will however send back the electric wiper conversion from Classic Parts, they forgot to tell you that you will not be able to use the choke !, and the speed and sweep is very poor.
Yes, I can relocate the choke, but who wants to look at an empty hole in that purdy dash?
Rolf
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Rolf,I have the 12 volt newport wiper motor,It worked fine when i had the original engine in the truck.I have never heard of it interfering with the choke cable. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2002 Posts: 13 New Guy | | New Guy Joined: Feb 2002 Posts: 13 | The Newport motor is from a different company, and may be better engineered. This unit sits directly in front of the choke cable, several Stovebolters have reported the same.
Classic Parts seemed indifferent, they just said they have not had any returns. The sweep was 2/3 of the glass with no slack in linkage, and the speed was dismal.
I just sent it back, I may just make my own.
Rolf
