| | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 6 New Guy | | New Guy Joined: Jan 2010 Posts: 6 | hi guys, this is my first post. im wanting to know the year of my 235, if the number on the head is the cast (correct me if not) its 3886848 and the # by the dist is F0408J any help is apprectiated | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | the serial number comes up '59-'62, and is a truck application engine. There is a casting date code on the engine. It's behind the starter on the right side of the block. It should have a month/year code.
Bill Burmeister | | | | | Joined: Jan 2010 Posts: 6 New Guy | | New Guy Joined: Jan 2010 Posts: 6 | thanks bill i will go look and be right back | | | | | Joined: Jan 2010 Posts: 6 New Guy | | New Guy Joined: Jan 2010 Posts: 6 | thanks bill i will go look and be right back | | | | | Joined: Jan 2010 Posts: 6 New Guy | | New Guy Joined: Jan 2010 Posts: 6 | right bhind the starter left to right reads
00NG D 60 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Jan 2010 Posts: 6 New Guy | | New Guy Joined: Jan 2010 Posts: 6 | | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | That is great Stovebolt service!!! Nice work. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Hi Brott, and Welcome to The Stovebolt. Here's a great website with tons of info. Although the page is for 1959, it will help you understand your engine serial number. http://chevy.oldcarmanualproject.com/chevyresto/59tsn03.htmThe head casting number you posted should be 3836848. Sometimes those 3's & 8's are hard to read. Your block also has a casting number on the same side as the date code. Can you post it when you get a chance. It will be something like 3738307.
-Tom
1950 Chevy 3100 w/ 1956 235
