3 members (Southerntruck, 2-Ton, 1 invisible),
78
Mod | | | Forums66 Topics128,142 Posts1,056,491 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 117 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 117 | where is a good place to get a wiring harness?? reasonal too, $$, mick
care to chat write back
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That depends on what you are looking for, a factory style harness or a universal harness. I used the 12 circuit from Hot Rod Wires in my '56 and I'm really happy with it. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | If its a stock truck why not do your own? I have rewired my 49 with good wire, new terminals, a good crimping tool and the electrical schematic from the shop manual. Its really quite easy except when you have to work under the dash. Fusebox forward is child's play. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If you're wanting an OEM looking harness you won't find one cheap.
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I am going to Classic Parts of America (old Chevy Duty) for the harness on my 48.
I put their harness on my 55 2nd some years ago and have had no problems. Their price is $148. Get the one which will fit your needs. They have one for an alternator or generator. I stay with the original equipment - generator. Pretty basic.
It is an easy install.
I hope this helps
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | Jim Carter Truck Parts has many harnesses in stock both modern and stock. OR Give me a call. I may have something that can help you Poets Seat AutoAppraisals, Parts, ServicePast: General Motor's Master Technician Member: Northeast Chevy/GMC Truck ClubPhone Number: 413.774.5856 Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
