Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (TeW, Guitplayer, Otto Skorzeny, 2-Ton, Hanks custodian), 238 guests, and 5 robots.
Topics128,281
Posts1,058,484
Members48,490
#619580 02/13/2010 7:07 PM
1 Offline
is this about right? any way to bump that up? spendy plugs or such?what kinda mpg do the 350/350 guys get? and how much of a pain is the swap from 235 3 on the tree to 350/350?
16hp #619627 02/13/2010 9:48 PM
Riding in the Passing Lane
I take it this is the 62 in your profile. That's not enough. A good tune is the first thing. Check the timing & vacuum advance. If you have a Roch. model B carb it is easy to take off the top & check the float level & make sure the power valve is free. If you pull the carb there is a hole in the bottom. It has to have a gasket that allows vacuum to get to that hole. You don't need any high dollar plugs. That should get you 12-14 mpg. I f you do a lot of highway driveing you will want to go to a better gear ratio like different rear end gears or an o-drive trans. Swapping to a v-8 & auto is not too difficult on this truck but it all depends on your expertise.
1972 Chevy c10 Cheyenne Super
1 Offline
thanks wrench. i'll check that valve and send her for a tune.
