2 members (2-Ton, 1 invisible),
108
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 42 Apprentice | | Apprentice Joined: Sep 2009 Posts: 42 | I have a 54 chevy pickup that is partially disassembled. The front end is off the frame. I need the dimension from the firewall to the radiator. If someone could throw a tape measure under their hood I would appreciate it.
Thanks, Brian
Brian Hill
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | | | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | Hi Brian,
Here are a few dimensions from a 55 first. 30-5/8 inches firewall to radiator on center line of truck. On drivers side 31-1/4 inches firewall to radiator support. On passenger side 31-5/8 inches firewall to radiator support. | | |
