0 members (),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | My objective is to remove the torque tube style drive shaft and rearend and install a '69 camaro 10 bolt posi with highway friendly gears (2.73)'s. Wanting to stick with a truck style 4 speed (SM420, I thought I needed to get an open drive shaft style transmission .ie. '55-'67 SM420 transmission. I did purchase what I believe to be a '55 SM420.
OK, here's the deal... Upon scraping decades of dirt and New Mexico grime from my "54 1/2T with original SM420 4 speed transmission. It appears to me that I could just swap out the "transmission rear bearing retainer" with the one on the '55 and not have to swap transmissions.
Can someone shed some light on what may be my $250 and countless hours of cleaning 1955 "transmission rear bearing retainer"? Of course it is attached to what appears to be an excellent working transmission.
Thanks | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I know someone who has done the rear retainer swap so while I can't tell you the details, I believe it can be done.
While you have it apart anyway I'd try to ascertain while transmission is in better condition and go with that one.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You ought to put new bearings and gaskets and replace anything else that needs it in the '55 tranny before you pull your rear end swap, then you'd have a known fresh tranny to go with it and won't have to wonder. | | |
