2 members (Mike Roache, walter74), 110 guests, and 2 robots.
Topics128,049
Posts1,055,740
#619089 02/12/2010 1:43 AM
My 53 chevy has an original 216. im looking for another straight 6 motor and manual trasmission that i can drop in with no major modifications. will a 291 straight 6 work? thanks
You say 291, do you mean 292 or 261? Or have I missed it entirely?
The answer depends on what you mean by major modifications and how much more power you want.
The 292 is probably the most major of the GM sixes with the related 230 and 250 being a little less trouble but not much.
A Chevy 261 is almost a drop in swap. A GMC 270 or 302 will provide more power and is only a little more work.
What Steve Said.
However you have to define what "no major modifications" is. A 235 with a low pressure turbo would bolt in, and have more power. A 261 will bolt in. A 194/230/250/292 will require a different bell housing, starter, trans cross member and fabrication of mounts.
