7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | Ok guys, here is what I got going on. 235cui (1957 3200) dual carbs. HEI-MINI elec ingition from Tom Langdon. Starts up fine, runs very well. Gets hot, and my ignition starts breaking down. Spark gets weak, and eventually stalls out when engine is reved. HEI is 2 months old. Toggle switch from dash with #10 wire as recommended by Langdon Stovebolt. Coil test shows that the coil is 100%. Timing light shows perfect timing.  JOHN in VA | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What do you have the timing set at? It sounds like you need a bit more advance.
Bill Burmeister | | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | a simple advance in the timing could stop it from stalling once warmed up?? | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | if it stalls and wont start until its cool, then it sounds like a bad HEI module.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Try reinstalling your points if the problem goes away than you would need a new HEI, it's easy to do and would tell you alot about whats going on.
Good luck,Pete | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | You might try this, go to an electronics store and get some "cold spray," or possibly use the air from your compressor (reduced flow). Let the engine warm up to the point when it begins to stumble, before cutting out. Spray the most likely components one at a time, and see if when you cool a particular component, if the engine goes back to smooth idle. | | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | We need more information. What is getting hot? The radiator/water temperature, the distributor, the coil, or something else? | | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | When I say 'gets hot' I dont mean a particualr part. I just mean that when the engine gets to her running tempo, ignition begins to break down. Slight backfire begins, then with reving, she will eventually stall out. Some people have been telling me to replace the module...I may go this route. JOHN | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | +1 on the "cool it down" advice. Pick up a can of R-134 refrigerant and a can tap, and hose the module down with liquid Freon by holding the can upside down and opening the tap when the stumble begins. If the performance improves for a short time, you've found the problem. Keep your fingers out of the spray- - - - -it's about 40 below zero! Jerry
| | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | I have the same setup you do. Late model 235 with a Langdon HEI. I love it. Are you using the correct plugs, wires, and gap settings as recommended by Langdon? Is your timing set at 10 to 18 degrees BTDC as he recommends? Did you solder your wire connections? I was having problems with mine, which turned out to be a bad ignition switch. I spoke with Tom Langdon and he said the module is almost never the problem. He said the module either works or doesn't work (nothing in between). | | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | ***UPDATE** ... I replaced the module inside the distributor. Tom Langdon sent me another one since this one went after only being in there for 1 month. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | make sure you use the heat sink grease or you will kill the next module.
