7 members (Shade Baby, 68ironhead, rinemb, Otto Skorzeny, elhippie64, Gdads51, 1 invisible), 214 guests, and 3 robots.
Topics128,095
Posts1,056,075
Members48,433
#618258 02/09/2010 6:47 AM
Posted this over at inliners but no response yet...Looking to upgrade the single Rochester to a dual carb set up on my stock 65 C10. I had initially thought of using a Clifford 4 barrel manifold with a 390 cfm carb. I ran 2 Carter W1`s on my 55 pickup and found the response off idle to be lacking. What would be a good pair of carbs to run on a stock 230 with a split exhaust? Which manifold would be recommended?
1955 Chevy 3100
Have you considered running a single 2 bbl on an adapter to your stock intake manifold. It would be an easier hook up I think. Tom Langdon has the set up on his store site. But, if you're definitely set on the 2 1bbl set up,I'd still use the W-1's with maybe a rejet up 2 steps from whatever you have in them now. I'd use an Offy intake for the 230. You might even find one in the Summit catalogue.
Drew
Carburetion specialist
If you still have the dual Carter W-1's, you might consider retrying these.
Chances are either the adjustment was wrong, or some of the linkage was worn. These normally give excellent results.
Give me a call at 573-392-7378 (9-4 Mon-Wed central time); and I will be happy to describe what to look for.
Jon.
The Carburetor Shop
Thanks carbking and will talk to you when I get back to that stage. Would you reccomend the 574S?
1955 Chevy 3100
A pair of 574s Carters should work very well.
Jon.
The Carburetor Shop
