| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61813 06/16/2006 4:19 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I'm getting ready to put my 302 back together. I have a 270 harmonic ballancer that was ballanced with the rest of the internals of the engine. I also have a millitary HB with 2 belt grooves.
Does it matter which one I use? Are there any other cost effecient options? The 302 ballancer seems much larger and heavier. | | |
#61814 06/17/2006 10:19 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | If you intend to actually drive the truck, use the damper designed for the 302.Using a the wrong one can lead to bearing failure and at worst a broken crank. | | |
