5 members (52Carl, klhansen, Otto Skorzeny, farmallb, rick46ia), 75 guests, and 13 robots.
Topics128,021
Posts1,055,354
Members48,420
#61813 06/16/2006 4:19 AM
I'm getting ready to put my 302 back together. I have a 270 harmonic ballancer that was ballanced with the rest of the internals of the engine. I also have a millitary HB with 2 belt grooves.
Does it matter which one I use? Are there any other cost effecient options? The 302 ballancer seems much larger and heavier.
#61814 06/17/2006 10:19 AM
If you intend to actually drive the truck, use the damper designed for the 302.Using a the wrong one can lead to bearing failure and at worst a broken crank.
