| | | Forums66 Topics128,053 Posts1,055,776 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61807 06/16/2006 2:49 AM | Joined: Jul 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 72 | Hi Guys, Wondering about putting two carter yf's on my 235. Think this is a good setup? Autozone sells these for about $100 with the core charge added in. Any thoughts ( money is no object, HA HA). Will there be any modifications needed or is this a good combo. Any help is greatly appreciated. | | |
#61808 06/16/2006 3:59 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Carbking may chime in here but I'll tell you what I've found out. The YFs are a good choice for duals on a 235. The thing you want to watch for is to get the right YF. I know they made a bunch of different kinds. (this is where carbking will help out) Also they have to be identical carbs to function properly. I'd say go for it, should work out well for you. You might want to contact carbking directly for his input. Good Luck George | | |
#61809 06/16/2006 4:13 PM | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | Do a search on Carter YF posted by carbking. There is a listing of the various YF's that were used as replacement for Chevrolet.
Pay attention to the throttle size (2 or 3, center to center 2 11/16 or 2 15/16 inches) required by your manifold.
Trying to adjust the non-Chevrolet YF's will cost more (even if they are given to you!!!) than starting with the carbs with the Chevrolet fuel curve.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#61810 06/16/2006 4:59 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Watch out on those reman YF's!! I had a pair form Tomco that were supposed to be for Chevrolet. One turned out be a ferd carb. The innards are slightly different, mainly the needle and jet. Parts seem to be hard to get if you need to convert ont to Chevy spec. I ended up putting Holleys on my 235, and am much happier with them.
Bill Burmeister | | |
#61811 06/16/2006 8:01 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | If you do find a matched set, they run nice. I've got a matched pair of 216 YF's on an Edelbrock manifold on my 216 and I've been real happy with it. Runs real good with no hesitation or lag whatsoever.
But I'm going to be switching manifold and carbs soon. I've run this setup for about 4 years now and it's time for a change. I've got a Weiand manifold and will be running a pair of Carter W-1's, #574s. I like to fiddle with things so I'll see how this setup works.
Bob | | |
#61812 06/16/2006 9:34 PM | Joined: Jul 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 72 | Hey guys thanks for your info. Have a Sharp manifold and been dying to put it on but have been scared to mess with the Rochesters I have. Will linkage and fuel lines hookup similiar to the rochesters?
If anyone thinks of anything else I should know about, any info is appreciated. I love the way we all help each other out. I hope to be able to help some other Stovebolter out some day! | | |
