3 members (pdlightning, 54farmtruck, klhansen), 375 guests, and 2 robots.
Topics128,168
Posts1,057,098
Members48,463
Page 2 of 2 1 2
SO I just found a CC truck.. its an SRW though from the photos.... think its a van axle?
I'm waiting on a call from the guy...
Jeremy
1950 Chevy 3800 1-Ton Long Bed
More pix on Flickr
Sold all the bikes, leaving California behind.
This swap works if you start with a newer 14 bolt Dual Rear wheel axle from a cab and chassis. then you install single rear wheels on it.
It will not work if you start with a single rear wheel axle, well not and fit the wheels under fenders on a step side pickup bed..
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
OK that's what I thought. I'd never seen a CC with single rear wheels. Thanks.
More pix on Flickr
Back to the 14 bolt rear axle swap for an AD truck.
Originally Posted by Grigg
The 14 bolt Cab and Chassis axle I have has 13" x 3.5" brakes for dual wheels. Drums I think are NAPA # NB 4401652
Napa # NB 4401651 is a single wheel drum with the same brake size.
To use the single wheel brake the backing plate will need about a 1-5/16" spacer between it and the bracket on the axle tube. Which gives this much more room between springs and backing plate.
One problem may be the two different drums in question mount differently. The single wheel drum is intended to slip over the hub, and the dual wheel drum is installed on the hub then the whole assembly is installed on the axle.
I expect that the single wheel drum can be installed first just like the dual wheel one was.
Grigg
I think I'll use single wheel drums and make new backing plate mounting flanges and weld them to the axle tubes in the proper place. That will make plenty of room for springs and u-bolts.
It'll be a while before I do this, but now having had plenty of time to think about it that's where I stand on the thought process.
Grigg
---All pictures---
I'm curious (as a new owner of a '50 GMC 250 with no bed on it) if a Cab and Chassis rear end WITH dual rear wheels would fit...considring that I'd then plan to use a flatbed.
I think if the drums will clear the springs and chassis, that the tires will to...but I'd like to know what you all think.
I'd prefer the narrower overall width of the C&C rear end if it will fit.
Thanks!
Clem
1950 GMC 1 Ton
I believe I give the WMS measurement, and if you know the depth of your wheels and width over the springs you'll have a pretty good answer.
I'll check sometime if I get a chance, or let us know what you find.
Grigg
---All pictures---
Bringing this thread back to the top.
Haven't made any progress on the swap...
However I have been thinking about it a lot and decided that making spacers for the backing plates to move them out and allow for mounting the original drums outboard of the hub is pretty simple and not a bad solution. This will give plenty of room for U-bolts between the spring and backing plates.
A more expensive version of that is buy single wheel brake drums of the same shoe width and diameter, then make and weld new backing plate mounting flanges in the appropriate spot on the axle (use original backing plates/brakes). If you already had to buy new drums this is the cleaner approach. Because of the distance the backing plate moves it's probably not a good idea to make a simple spacer.... it should be welded in place.
Grigg
---All pictures---
Grigg,
How did the axle swap go? I have been looking for a 14 bolt for my 1-ton. I found a few but but really dont know what Im looking for other than 14 bolt dual from a C&C. I found two that meet my with requirement of 63". They both seem to have the same casting number.
http://i1062.photobucket.com/albums...2-426B-8011-9BE0A53367C3_zpsauscpole.jpg
http://i1062.photobucket.com/albums...5-419D-A743-73F928C7F891_zpsjphxxqbh.jpg
the drums just look awful big compared to the stock HO72 drums..
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
I can't help you with the casting numbers, but it otherwise sounds like you've found what you need in one or both of those axles.
Yes, the drums are large and that's a good thing, they'll work well.
Only downside to the drums and being so deep (originaly for dual wheels) is you'll see a lot of the drums from the rear, the single wheels won't cover them.
If you can live with this then only modification that I know of to make it fit your truck is moving the spring pads to match the springs.
If you don't like that look then you can keep the very same backing plate and shoes and purchase new drums intended for a single wheel truck. To make this work you will also need to remove and relocate, or better yet, make/buy new flanges to weld to the axle for the backing plates.
Or there are ready made disc brake brackets and parts list for which rotors and calipers to buy. The downside to this is loss of parking brake in the wheels if you had those. If you do want disc and parking brake they make calipers that do but they're expensive. With disc in the rear you shuld really have them in the front as well. And lastly I'm not sure if the disc are any better than those huge drum brakes?
I know it's been several years now but I have not made progres on this swap myself. Life happens as they say.
However I have not given up and all my parts and pieces are dry and safe waiting for the right oportunity to use them.
Grigg
---All pictures---
Thanks again Grigg, I did some research on the web and best I can tell those casting numbers check back to the 14 bolt c&c 10.5 free floating rear end. So I think I am going to go with it. being my truck is a flat bed I wonder if the dual's (original to the axle) would fit back on there after the axle is mounted (as an option).
If they don't hit the springs which are about 1" closer to the tire on our trucks with 36" frame than when in the later model truck and 34" frame.
Measure and see.
---All pictures---
I just stumbled across this, alot of good info on the 14 bolt axles.
http://billavista.com/tech/Articles/14-Bolt_Disc_Brakes_V2/index.html
Nice link, thanks
---All pictures---
Page 2 of 2 1 2
Moderated by  Dusty53
