7 members (Donf, JoeDude, 48jim1ton, gswbbc, frogfarmer, Gdads51, Gib70),
109
Mod | | | Forums66 Topics128,035 Posts1,055,528 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 15 New Guy | | New Guy Joined: Dec 2009 Posts: 15 | Hello from England,
I have a 1955 first series, could someone tell me where the Brake light switch is please. Are there any regular "look here first" areas I would be greatful of any help.
Laine | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Laine, Look on the engine side of the firewall. You will find a switch like this mounted to the firewall, behind the bar down to the master cylinder. The lever on the switch moves when you press down the brake pedal. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Don’t know for sure Tim if the brake light switch mounting is the same but here’s a picture of the one on my 1950, 3600. http://www.pbase.com/dennygraham/image/121766796/large Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A picture is worth a few dozen poorly chosen words.
Good picture, as usual, Denny (it's the same from 47 to 55-1st)
| | | | | Joined: Dec 2009 Posts: 15 New Guy | | New Guy Joined: Dec 2009 Posts: 15 | Hello,
Thank you for your comments, switch now found and fixed.
Laine | | |
