2 members (gswbbc, wilbur53),
139
Mod | | | Forums66 Topics128,035 Posts1,055,446 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | On my 1948 chev 3600 I have both rear wheels off the ground and can turn passenger side fairly easy. The drivers side turn backwards hard but not forwards.I believe the brake is not stuck. Is there anybody that this has happend to before or any suggestions.Is this normal? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Definetly not normal. It should be the same on both sides, and trun the samd either direction. It sounds like there's an issue in the left side brake, perhaps a broken spring or worn link allowing a shoe to wedge in the drum when turning the wheel backward. Best bet will be to remove the drum and see what's going on inside.
Bill Burmeister | | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | I will check that in the morning, i did have the drum off once and thought everthing looked good but maybe I missed something.Do you think it could be a more serious problem with the axel? When I turn passenger side backwards the drivers side also turns backward, but not forwards. Thanks | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | What happens when you leave it in gear and turn the passenger's side? It sounds like you might have a modified differential in there. | | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | I have not tried that. Never heard of a modified differential could you expand on that a bit.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I think what he's meaning is that perhaps a po has installed a locking differential, like a No-Spin, in it.
Bill Burmeister | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | When you said that you turn the passenger's side backwards and it causes the driver's side to turn backwartds at the same time, this is something that will only happen with a limited slip or some other type of differential. If this is the case and you put it in gear, you probably won't be able to turn it at all. On a normal differential, the wheel on the opposite side will turn the other way. | | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | I will try to do that in the morning as my truck is at my shop which is some distance from my home. Would it be fair to think that it is a minor problem since both wheels do turn backwards. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think it would mean that someone has installed a different differential that may actually be an upgrade of sorts. | | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | Why would the drivers side not turn forward if it turns backwards | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I think you have a brake cable that is hanging up or the emerg. brake is adjusted up too tight. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | Problem solved I took off the drum and cleaned up the inside and now it turns. The truck sat for some time and I guess it just kinda cruded up. Stupid Me, Thanks for all the help I do appreciate it. | | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | Problem solved I took off the drum and cleaned up the inside and now it turns. The truck sat for some time and I guess it just kinda cruded up. Stupid Me, Thanks for all the help I do appreciate it. | | |
