5 members (EchoBravoSierra, BarryP, Otto Skorzeny, Shade Baby, Phak1), 156 guests, and 1 robot.
Topics128,162
Posts1,056,910
Members48,458
getting ready to replace the front wheel bearings on my 54 to roller bearings from the original ball bearings. what advantages is it going to give me in handling? will it keep it from being so squirrelly? i've got radial tires one and sometimes it wants to wonder a bit. course it just be the nature of the beast.
If your ball bearings are in good condition and properly adjusted there will be no difference in handling at all.
Do you know the wheel bearings are bad?
Have you checked the king pins, tie rod ends and the drag link? Have you checked to be sure the wheels are straight? All these are far more likely to cause squirrelly than wheel bearings.
Wheel bearings have very little bearing on handling. Loose steering box, drag link, and tie rod will cause it to road walk. Also alignment such as toe in, caster and camber will effect steering. Loose king pins will affect tire ware more than handling. When everything is right, they steer pretty good. Most 55 year old vehicles have a lot of wear and follow the low spots of the road and get blown around by the wind. Constantly correcting while driving was just a part of driving. The bottom line is, if you want it to steer well, don't expect just one item, especially bearings, to help.
i didn't figure they would do much. just wanting to start looking somewhere. how do i tell if the kingpins are worn? when i grab the tire and rock it top and bottom there isn't much play in it.
How much isn't much?
Do you have original-style, adjustable tie rod ends? Have you checked their adjustment.
I have a tight, original-style parts, front-end on my Suburban. It cruises straight (no wandering) at 65 mph (with high-profile LT radial tires).
