0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you can use a low tech battery charger rather than buying a dedicated limited use item, even just use a good battery for a short test [use an inline fuse] - you need about 5-10 amps max
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep do like Bill suggests, just use your 6v battery. You can pick up a couple of pairs of alagator clips and some standed wire from the hardware or autoparts and make up a set of jumpers for your radios testing. That test bench power supply isn't rated high enough for your 6v radio work. DG
Denny G Sandwich, IL
