3 members (Bill Hanlon, Hanks custodian, Nick in Manitou), 75 guests, and 3 robots.
Topics128,080
Posts1,055,953
Members48,430
#617466 02/07/2010 12:29 AM
I checked the Stovebolt Tech Tips and they suggest i need a power supply. Will this one work for my 51 radio from my 6V truck? Of will this power supply not give me enough amps? Thanks
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200434833030&ssPageName=STRK:MEWAX:IT
'51 Chevrolet 3100 216 5-Window
chevnky #617468 02/07/2010 12:35 AM
you can use a low tech battery charger rather than buying a dedicated limited use item, even just use a good battery for a short test [use an inline fuse] - you need about 5-10 amps max
squeeze #617532 02/07/2010 4:02 AM
Yep do like Bill suggests, just use your 6v battery. You can pick up a couple of pairs of alagator clips and some standed wire from the hardware or autoparts and make up a set of jumpers for your radios testing. That test bench power supply isn't rated high enough for your 6v radio work.
DG
Denny G
Sandwich, IL
Moderated by  ndkid275, Phak1
