0 members (), 118 guests, and 3 robots.
Topics128,196
Posts1,057,393
Members48,471
Found on RockAuto.com: Rhinopac makes a conversion clutch kit for the S-10 pickup and Camaros with the 2.8L V6 that could be used on an Advance Design truck. The AD has a car-sized bellhousing hole that fits the T-5 front bearing retainer perfectly.
RHINOPAC Part # 04054
Base; Disc Spec: 10-3/8" OD X 1" ID X 14T, Flywheel Spec: FLAT; Use when converting to a small block V8 and using the OE 1” x 14T spline transmission. Must use with a V8 bell housing and flywheel. It may be necessary to alter the disc hub spline length.
Has anyone tried this part?
http://www.fatherley.com/trucks.html
Q: Is it transportation or is it yard art?
Riding in the Passing Lane
I tried one. I used the disc but the pressure plate does not fit the truck flywheel. It must be for the small flywheel.
1972 Chevy c10 Cheyenne Super
