1 members (1 invisible), 105 guests, and 3 robots.
Topics128,089
Posts1,056,440
Members48,443
I've got several sources for V8 numbers, but I've got several unlabeled six-cylinder cranks that I need to id so someone can adopt them.
Anybody got a list, or know a source?
Wild Turkey
"If your only tool is a hammer, you tend to see every problem as a nail"
-Tom
1950 Chevy 3100 w/ 1956 235
post the numbers and see if we can help with them.
Oilrag, that looks interesting. I'll pull those numbers this evening.
Here's some of the numbers (can't id maker on these):
212
21355416
2191127
4095246
414699
3876802
3820618
3855914
These are part of a truckload of unclaimed cranks from a closed machine shop. I've got everything from an inline 8 to a Caterpillar 2-cylinder :confused:
Right now I'm just trying to get a reliable list of numbers so I can put these poor cranks up for adoption cool
Wild Turkey
Wild Turkey , I made some of the castng out but others I wasn't so lucky.You might give me some more information if possible .I believe the 2nd number 21355416 should be a 2135416.
212- I can not identify
21355416-GM
2191127-GM
4095246-Chrysler 3.7/225 L6
414699 -?
3876802-GM 4.1/4.6 L6
3820618-GM 215 Pontiac or a 230 GM
3855914-GM / Pontiac
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
2191127 - 1939-52 248-236-228 Cu. in. GMC
2135416 - 1942-53 270 Cu. in. GMC
3820618 - 1962-70 230-194 Cu. in. Chevy Pass & Truck
1963-70 230-194 Cu. in. GMC
1964-65 215 Cu. in. Pontiac
1965-66 230-194 Cu. in. Studebaker
3855914 - 1963-66 292 Cu. in. Chevy Truck & GMC, 7/16" bolt holes.
3876802 - 1966-74 250 Cu. in. Chevy Pass. & Truck, GMC & Oldsmobile, crankneck 1.2465
1968-74 250 Cu. in. Pontiac O.H.C.
-Tom
Thanks for the help -- but that raises a follow-up question: were all the cranks with the same casting number ( 2191127 ) forged?
I've confirmed one is forged, but there are several others I haven't checked.
It seems from what I've seen that cast and forged cranks would generally have different numbers, but I'm wondering.
Wild Turkey
Listed as "crank forging" #'s.
1939-52 had Dome Pistons, 5/8"
Block casting # for the 228 CI is 6107326.
Block casting # for the 248 CI is 6107328.
Both used crank forging # 6107342 or 2191127.
Both used head casting # 2136477 or 6107412.
1953 -248 CI had Flat Pistons. Same block, same crank forging #, head casting # 2194819.
-Tom
