2 members (baldeagle, dunfire),
86
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | Could anyone out there be kind enough to give me the dipstick dimensions for a 1946 235 1.5 ton? I need the overall length, length between each level indicator, and length from end tip (bottom) to top plug. I am planning on fabricating an aftermarket dipstick. Thanks, guys.
Adam
1946 2 Ton Flatbed
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 |
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I seem to remember a discussion about this a while back and the tube length was given. mine measures 6" outside of the casting, you would add the depth of the counter bore to that. You can use one of those 3/8" made up brake lines from you FLAPS for the tube. Then to calibrate the dip stick just simply add four quarts and mark it one quart low, then add that last quart and mark it full.
DG
Denny G Sandwich, IL
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks, Denny.
Over the years I have collected a bunch of dipsticks from engines I have bought, trashed, and rebuilt. They are all from 216 or 235 engines. They are different looks and lengths. I have always wondered how to tell which goes to what.
Your description is helpful
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | Thanks, guys. The calibrating technique is very helpful. So, if the tube is 6 inches, then is the dipstick itself six inches plus whatever comes out the top of the tube for handle purposes?
1946 2 Ton Flatbed
| | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 |
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
