1 members (Hotrod Lincoln),
327
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | hey guys, 20amp in-line fuse from dashboard toggle switch to positive on battery for my ignition blew. 10guage wire (HEI mini from LANGDONS STOVEBOLT)..I just changed the distributor module, went to start it, and the inline blew. Anything to be concerned about? should I use a higher amp fuse? a 30amp? '57 235cui thanks | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That seems like a lot of current to me. I definitely would not put a bigger fuse in. | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Has the system been operating normally before the module change? It sounds like you've got a dead short somewhere, or maybe an incorrect wiring connection. It's not unusual for a HEI system to draw lots of primary current, but a 20 amp fuse should carry the load OK. I'm not familiar with that system- - - - -which distributor and module does it use as the basic unit? Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I would check everything for a short somewhere but I would never put a fuse in an ign. system. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
