1 members (delky), 130 guests, and 3 robots.
Topics128,062
Posts1,055,854
Members48,428
#609684 01/13/2010 7:57 AM
I am having some trouble with a third row seat for my 51 suburban.
The bottom supports do not line up with the mounting holes that are on the floor?
Trying to figure out if I have the correct seat or if the mounting brackets on the floor are placed wrong?
Does anybody have pictures of third row seats, 47-54 and 55-59 so I could compare with mine. Also some pictures of the floor area would help too.
I dont want to make anymore holes or modify the seat. Would rather trade with someone who has the wrong seat....if i have the wrong one?
Hope all makes sense? headscratch
Thanks in advanced
Javier
Javier, it's hard to help without pictures. pix If the mounting frames do not line up, most likely you have a seat from another make. From what has been discussed, the seat mounting frames are the same and they do exchange position with each other.
The seats fit from 1947/1959 GMC/CHEVROLET suburban. The information can be found on this [font:Arial Black]previous topic[/font] There are some measurements that should help you.
Here are some photos of the rear-seat base but no measurements are included.
The color rendition is poor (too red) and some phoos are dark - sorry.
Here are some pix of the third row suburban seat I have.
It looks like the pictures you sent.
The only different thing i see is the side grab handle? that connects top to bottom frames at the sides.
My seat has flat pieces of metal, all other seats I see have a tubuler bar?
Thats what makes me believe its from a 55-59 suburban or other make?
Suburban Third row seat / A
Suburban third row seat / B
Suburban thrid row seat/b
I have one like that too. It's not a suburban seat. I think it might be from a travelall I have never tried to line it up with my floor. I figured I could make it work with a little fabrication.
Your middle seat looks like it's from a 1960/66 Chevrolet suburban.
Those mounting holes look to be in the right place. Perhaps the frame is tweaked a little.
Cletis, does your middle seat look like the one in his first photo? Suburban third row seat/b It's the one in front of the third seat.
Thanks guys for all the info. Very helpfull.
I do have the correct front row and second seats. As a matter fact I have two sets of front row.
I will take some measurments and see if the floor holes are the same as "cletis's" measurments.
I'll take some pix and post also.
Cletis, I have a driver seat, possibly a second row seat that looks like the picture you posted.
Suburban driver / second row seat
so did you have the correct 3rd row seat ?
New but in an Old Way !!!
I will have to re-adjust the mounting holes on the floor of my burb.
