5 members (wilbur53, WICruiser, panel fan, GMCJammer51, Hush), 127 guests, and 2 robots.
Topics128,038
Posts1,055,471
Members48,424
#616926 02/05/2010 2:33 AM
Could anyone out there be kind enough to give me the dipstick dimensions for a 1946 235 1.5 ton? I need the overall length, length between each level indicator, and length from end tip (bottom) to top plug. I am planning on fabricating an aftermarket dipstick. Thanks, guys.
Adam
1946 2 Ton Flatbed
Some info is here...
Rod-Tube, oil level gauge.
http://chevy.oldcarmanualproject.com/1929_54chevyparts/01/131.HTM
-Tom
1950 Chevy 3100 w/ 1956 235
I seem to remember a discussion about this a while back and the tube length was given. mine measures 6" outside of the casting, you would add the depth of the counter bore to that. You can use one of those 3/8" made up brake lines from you FLAPS for the tube.
Then to calibrate the dip stick just simply add four quarts and mark it one quart low, then add that last quart and mark it full.
DG
Denny G
Sandwich, IL
Thanks, Denny.
Over the years I have collected a bunch of dipsticks from engines I have bought, trashed, and rebuilt. They are all from 216 or 235 engines. They are different looks and lengths. I have always wondered how to tell which goes to what.
Your description is helpful
Dennis
Thanks, guys. The calibrating technique is very helpful. So, if the tube is 6 inches, then is the dipstick itself six inches plus whatever comes out the top of the tube for handle purposes?
1946 2 Ton Flatbed
https://www.stovebolt.com/ubbthread...;Main=78002&Number=553835#Post553835
This is the info I was given awhile back for my '57.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
