| | | Forums66 Topics128,079 Posts1,056,297 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 15 New Guy | | New Guy Joined: Apr 2009 Posts: 15 | got my cab mounted onto the S-10 frame, now trying to figure out how to get the brake pedal on the right side of the steering colum. I'll be using a standard transmission and the clutch pedal does not hang from the under dash brace like most do. I'm using the pedal assembly out of the same s-10 as the frame came from (1987). the clutch master cylinder is attached to the floor and the pedal is attached to it by two (2) rods. Can you guys help me again. Thanks ahead of time. | | |
