0 members (), 133 guests, and 3 robots.
Topics128,115
Posts1,056,289
Members48,439
It ran fine for half the morning.
Made a coffee stop and when I tried to re-start, smoke came out of the starter...
The battery cables where super hot, too...
I took the starter out and had it rebuilt, thinking I fried it. I recharged the battery, re-installed the starter, new (thick) battery cables and... nothing happens...
Not a click, not a movement from the starter.
What should I do next?
Could the regulator be involved?
Any input would be appreciated, fellas!
whizzerick
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
Need some more info: Foot starter? Key switch start or push button? Year of truck?
If it has a start solenoid, is the start wire from the switch or push button connected to the correct terminal? NO click sounds like you have a solenoid starter. If so 'no click' is definitely a solenoid, switch or wireing issue.
That's a bummer Rick. I'd be suspicious of a burnt contact in the starter switch. Take it off and look inside. You might be able to clean it up. Good luck.
Curt B.
You Tube
'53 half ton. 235. Foot starter...
I would also check to make sure the foot pedal is engaging the starter, the leakage might be broke or out of whack,, I am sure you have already done this but,,,,,,,,,,,the bolt on mine use to come unscrewed and the foot part would just fall off as i hit it......
Redryder pix
My Hotrod
First things first, make sure you have voltage all the way to the starter. If you do, you can activate the starter with a pry bar right at the starter. If you don't, check your wiring. Especially your ground. Starters can be bench tested!
Ex Hall Monitor
Ex Hall Monitor
I second MNSmith. I would add what IBHoggin said about checking the starter switch too. It's easy to remove and dirt simple. Whoever rebuilt your started should have bench tested it but unless you there watching you don't know so if all else fails I would pull it and test it.
Okay, I'll try to 'jump' it...
Booster cables?
Neg to frame and + to starter terminal?
Yep.
