0 members (),
170
7
Mod | | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | On a 250ci engine, in a daily driver '57 Suburban, with a TH700R4 trans and GM throttle body EFI (but otherwise stock engine), which is the best intake, Clifford or Offenhauser? Torque rules!
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The thought had been that the Offy was a better street manifold, because of smaller runners. The smaller runners provide better low end, and mid range torque. Recent dyno tests on a 292 indicate that this may not be the case, for the 292. There are dyno tests in the planning stages for the 250, but it will be a few months before the data will be available. IMO the Offy would still be a safe bet for the 250 if your not looking at high RPM.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
