4 members (Gray_Ghost, BillCollins, Still At It, 1 invisible), 134 guests, and 2 robots.
Topics128,078
Posts1,056,054
Members48,433
#616456 02/03/2010 5:17 PM
hi guys... need some info... 65 chevy c10 350 engine 10 bolt rear end runs great but thinking running gears are too low for highway driving...do not want too change too disc brakes just now but would like too change third member suggestions please.....
Dawg65 #616505 02/03/2010 8:06 PM
A couple of questions, 1-What did the rearend come out of origianlly? 2-What size tires are you running?
If it's a later passenger 10 bolt, which I suspect due to the disk brakes, it will not have a removable 3rd member. You'll be looking at replacing the ring and pinion, and possibly the carrier depending on what ratio it has. Tire size will also affect what gear you need and what rpm you'll get running on the road. Too small of a tire will be the same as running a low rear gear.
Bill Burmeister
hi bill thanks for responding...... the truck has drum brakes and not disc.... also im running 16 inch tires with a 8 bolt lug.. as far as what this rear end came out of unknown... since im a back yard mechanic i do not know running rpm as no gauge installed... and i have not cracked nor opened the rear end....
thanks again bill .....
i bouught the truck with this rear end in it
Dawg65 #616909 02/05/2010 1:33 AM
Alright, that helps quite a bit actually. I misunderstood part of your original post, it kind of sounded like you had a disk brake rearend in it from a later vehicle. But now that we know you have a 3/4 or 1 ton rear (could it be that your truck is a C20 or C30, perhaps had the doghouse swapped by a po?), that will determine what options you have. from what you describe, you've got either a 4.56 or 5.15 rear gear, not very good for highway driving. The easiest fix would be to swap a 4.10 third member from a '68-'72 Chevy, usually found in automatic V8 equipped trucks. Those are in high demand, and may be hard to find. Another option, if you're up to swapping the entire rearend, would be to use the Spicer 60/70 that was found under GMCs from '60-'72. Those are for the most part leaf spring rear, thouhg I have seen a few coil spring versions, too. The Spicer rear still has plenty of support in the aftermarket, just about any gear you could want is available for those. You couls also consider the 14 bolt Corporate axle, which was used from '73 to current, though you would want to stay away from '99 and newer due to width issues.
You might also consider an overdrive trans, though there really aren't too many out there that are an easy swap with enough stength for a 3/4 ton truck. Others might chime in with options there.
Bill Burmeister
