| | | Forums66 Topics128,042 Posts1,055,501 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61631 06/12/2006 3:39 AM | Joined: Jun 2006 Posts: 3 Junior Member | | Junior Member Joined: Jun 2006 Posts: 3 | I have a 62 235 that has a treaded hole mid block that is "covered" by the side rocker cover plate, should this hole be plugged? The bulge in the side cover plate is over this hole. There is no threaded hole at the end of the cam bearings like on a babbit 235. thanks | | |
#61632 06/12/2006 6:51 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1958 is the first 235 without the steel tube behind the side cover, the oil now comes up the new cast in center oil galley. The plug blocks the hole the factory used to drill the oil passage and restrictor. You will need to use lifters with a wide groove on the outside also.
See the USA in your vintage Chevrolet! My Blog | | |
