1 members (baldeagle), 43 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#61631 06/12/2006 3:39 AM
Junior Member
Junior Member
I have a 62 235 that has a treaded hole mid block that is "covered" by the side rocker cover plate, should this hole be plugged? The bulge in the side cover plate is over this hole. There is no threaded hole at the end of the cam bearings like on a babbit 235. thanks
#61632 06/12/2006 6:51 AM
1958 is the first 235 without the steel tube behind the side cover, the oil now comes up the new cast in center oil galley. The plug blocks the hole the factory used to drill the oil passage and restrictor. You will need to use lifters with a wide groove on the outside also.
My Blog
