2 members (klhansen, 2-Ton),
85
Mod | | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | i am wondering why they sell a specific grille support panel for a 63. I am buying a 63 this weekend for parts and one part i need is this support panel for my 1965. does anyone have some thoughts on if it will work or not.
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | I think the grills had a different bolt pattern. The 63 grill was only made for one year. Whereas the 64-66 mounted the same. You could use it, but you would have to drill it out to mount the later grill on tghe earlier support panel. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The only difference is the bolt hole locations, as jon1963, so the '63 grille support will work with your '65 grille. | | | | | Joined: Jan 2010 Posts: 41 New Guy | | New Guy Joined: Jan 2010 Posts: 41 | i have found that 63 s are gender specific | | |
