5 members (Jon G, dt235sd, 1955 1 Series, Otto Skorzeny, 1 invisible), 100 guests, and 0 robots.
Topics128,049
Posts1,055,689
#616048 02/02/2010 5:22 PM
Removed hinges on my '57 and cleaned them up down to bare metal. What finish did they hare on them from the factory? What finish should I put on them to prevent them from rusting? I've sprayed clear on bare metal parts before only to have them rust under the clear.
originals were a cad plate sort of finish - I like high-zinc [weld thru] primer, has a similar appearance
squeeze #616063 02/02/2010 5:55 PM
There are also several great articles on Hinges and Strikers under the Body Work heading in the Tech Tips section that may be useful to you.
Drew
DrewP #616107 02/02/2010 7:29 PM
Didn't see anything in the tech tips section on finishing hood hinges.
High zinc weld thru primer: what is it and where do I get it?
my area it's in rattle cans at the FLAPS, various brands available - might also be labeled as "cold galvanize" paint, any of them are about 90% zinc solids, very good anti-rust
squeeze #616119 02/02/2010 8:23 PM
I've not seen that here. Wonder if it's one of those banned substances? Anyways, I'm looking and can always revert to buying something from Eastwood. Just wanted to get as much expert advice as I can before I spend a bunch of money on products. Thanks.
