1 members (Guitplayer),
104
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 15 New Guy | | New Guy Joined: Feb 2006 Posts: 15 | Hi All,
I have a 1953 3600, but it does not have the original 216ci engine. Rather, the engine is a 235ci. The most I've been able to determine is that the engine is a standard 235 model and was made on Feb. 6th, between 1957 and 1962. Apparently, from 1957 on forward, chevy 235ci engines stopped using serial numbers.
So, how do I determine the actual year of production for this engine? I have the following information from the engine block: Casting # = 3769716, Engine ID = F0206A, and two other strange things cast into the block and located below the Engine ID boss --> They are CON 4 and B52.
Can anybody shine some light on my confusion?
Thank you | | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | There is a machined pad just behind the distributor with a stamped number on it. The letter prefix at the beginning of the stamped number should identify the year of manufacture, and other details about that specific engine. There are several websites available with engine number decoding information, just google "Chevrolet engine numbers". Jerry EDIT: Try this link: http://clubs.hemmings.com/clubsites/chevytalk/GMhistory/cast.htmlBetter re-check that casting number- - - -you might have a 261 engine instead of a 235. If so, that's a real find! The casting number you list differs one digit from either a 235 or a 261 number. Jerry Found it! The Inliners' site lists your casting number as a 60/61 truck 235. http://www.inliners.org/becks/BCN2.htmlJerry
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | You're right about the serial no.s after '57, they just don't help much in ID'ing your engine. But, I think the B52 marking tells us the story, cast date of Feb 5, 1962.
If that's wrong, someone else will surely set the record straight. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I think that the 3769716 block casting code (235 ci block) was used from 1958-63.
As waldo53 posted, the date casting code is the clincher (1962).
| | | | | Joined: Jan 2010 Posts: 6 New Guy | | New Guy Joined: Jan 2010 Posts: 6 | hello all my first post, want to know what year my 235 is cast# 3886848 eng# F0408J
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The A code in the serial number denotes it's a Passenger application.
Bill Burmeister | | | | | Joined: Feb 2006 Posts: 15 New Guy | | New Guy Joined: Feb 2006 Posts: 15 | Thanks to all for your help and information!
Looks like the engine block was cast in Flint, Michigan on February 5th, 1960/61/62 (conflicting websites abound) and that its intended role was "Standard" (as designated by the 'A' serial number suffix).
So this little truck rolled along for almost a decade and then had its original 216 replaced by a plain jane 235.
Excellent nostalgia! | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | hi all, i have a 51 chev 5 window. it also has a 235. dont have the casting number but next to the distributor is #FO215JC. can anyone tell me what year the engine is from?? thanks
jeff gig harbor wa | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Brott, Where was the casting number 3886848 found? The block casting number reference that I use do not have that number. However, 3836848 is the cylinder head number for most 1956 and later 235 engines. Look at this serial number reference for the FO408J decoding. The engine casting number is on the lower forward passenger's side of the block. The casting date code on the block by the starter is also useful. Look at Tim's great site for more useful information. Hoyt | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 |
Here's a little more information:
on the block /distributor side: N375583 CAL on the cylinder head, intake and ex. side: 3701887 GM3 on the cylinder head, distributor side B2 887 O66 670 | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | N375583 CAL is a California assigned serial number. | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | So what do you think that means exactly? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 3701887 - 1953 head? From which locations did you find those codes (other than the head casting number and the engine serial number that Cetis has commented on)? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | I haven't seen the motor myself, so these locations are just hearsay from the current owner:
tclederman, I'll send him the link to that photo and get back to you all. As always, thanks for the input! | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | Hi tclederman and all, Here's additional info, with locations for each number as outlined in the numbered photos linked by tclederman here: Photo #2 Block Date Casting Code -- CON 4 G298 (G29=July 29, so is the "8" 1958? 1948?)Photo #3 Engine S/N -- dis. pad is N375583 Cal (Not sure what this means except that the 'cal' means it's a California s/n, as per cletis - is there any more information in the other part of the number?)Photo #4 -- B2 887 066 570 but didnt take valve cover off (no idea what this tells me)Photo #6 Casting Head Code -- 3701887 gm3 (I still can't find this particular code on any of the normal casting code sites - any ideas?) | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What did you find for #1, Block Casting Code? As I posted above (with a question mark), I found 3701887 listed for 1953 on one website (and I put it on my casting numbers web page), but the Hemmings/Chevytalk website did not say what 1953 235 engine - (Powerglide, manual car, or truck block). | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | Sorry tclederman, I missed that mention of the '53 head date. I've sent the guy a note to see if he can find the casting code in photo #1 on your site. | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Just looked at the pics. That is an interesting engine. It is a splash engine, as it has the three screw oil distributor. It has the 1952-54 side mount provision. 1953-55 head. 1950-62 side cover. Can't tell for sure from the pic. but it looks like a 41-52 water pump. I would say this was a crate 235, cast in 1958, for a 1953 passenger car with stick trans or big truck.,
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | Just got the casting number back: 3701946, so 1953.
You're right that it was for a big truck, it just came out of a 1951 2-ton.
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | I would also appreciate help in identifying the 235 I bought this past weekend. The PO says it came out of a '57 Chevy truck. Numbers and locations as follows:
Engine block stamp (on flat plate by dist.) FIII5H (These are the letter "I")
Head casting # 3836848
Manifild casting # 3836822
Engine block casting # (below and right of dist.) 3837004
I've gone to the Hemmings and Inliners sites linked to in the previous posts and cannot find much. Any help about the date of manufacture would be appreciated.
Chuck
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | The Inliners' site shows block # 3837004 as a 55-57 235. I'm not sure about the FIII5H; could it be F1115H? Sometimes the "1" looks like an "I". F1115 could mean an engine produced in Flint, November 15. For 1957, the "H" suffix seems to indicate a 31-32-36-3800 235. The head casting number is correct for a 1956-62 235. That casting number was also used for replacement heads for 1953 and later 235s. The casting date code behind the starter may also help. For example, F167 would indicate June 16, 1957.
Hoyt | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Hey Hoyt,
Thanks a lot for helping ID my motor. Yep, the III may indeed be a 111. I thought a series of letters instead of #'s and letters was weird, although I swear the things look like I's. I'll try taking off the starter to get at the casting code behind it. Bought this motor at a swap meet and I'd just like to find out all I can about it.
Many thanks!
Chuck
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | So finally got the other set of numbers off my 235 engine. they are 3763716. what year is this? the other set is "FO215JC" | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | head number is 3836368 GM29 | | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | I come up with Block 3769716 Chevrolet 60 235 w/HD clutch exc fwd control Head 3836386 Chevrolet 55-57 235 | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Hey Guys,quick question...what do the captain bars on the block mean? if anything... Thanks | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | The so called Captains Bars on the side of the block indicate it is a 261. Some early 261's didn't have them however. It is considered desirable and especially so by this crowd. | | | | | Joined: Apr 2005 Posts: 122 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 122 | After reading all of the posts, visiting each link, and collecting all the numbers from the block, I think I have decoded the engine in my 59 Chevy 1/2 ton Napco. It appears it is the wrong motor. Please take a look at my conclusion and let me know if I am right or wrong. Block casting Code - 3769716 = 1960 Block date-casting Code - Con 4 G60 = July 6, 1960. Engine Stamp Serial # FO 707A = Flint MI, July 7th 1960. Head Casting Code - 3836848 GM 30 = Number used for several years on 235. Head Casting Number - B59 848 = February 5th 1959 ? While it is a good running motor, if it is the wrong one I will probably be looking for a correct 59 engine. I am also confused by the fact that the throttle linkage seems to attach in a different location than my other 59, requiring the rod to to be shorter. I will need to modify linkage to get it to work. Once again your input and opinions are greatly appreciated and I look forward to responses. Thanks, Brian M | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | F0 707A is for a 1960 Passenger car or El Camino, which is why the throttle linkage mounting is different. A note on the Captains Bars, the '53 full pressure 235 used with Powerglide equipped cars had them as well.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 122 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 122 | Thanks. Looks like I'll be searching for a correct 59 motor. | | | | | Joined: Aug 2011 Posts: 7 New Guy | | New Guy Joined: Aug 2011 Posts: 7 | Ok I've got one. This is what I have so far: The VIN prefix: 1P352T 1 = 1961 P = Dubl-Duti Package delivery 35 = 1-Ton 125wb 2 = Chassis & Cowl T = Tarrytown NY Head Casting = 3836848 / GM 16 / CON 9 / F 9 0 / (#s by plugs) = B51 848 8503836848 = 1956-62 235 c.i. F90 = 06-09-1960 Block Casting = 3764476 / GM 8 / D 7 1 / CON 43764476 = 56or58-62 Truck 235 c.i. D71 = 04-07-1961 Serial = F04I9K 1 68Please let me know if I am screwing anything up here but I'm having the devil's own time decoding the engine serial # and that is what I need some help with. Most serial format sites stop at 1957 or I simply cannot find my format. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The engine serial number comes out as Flint engine plant, assembled April 19th, P20/P30 application.
Bill Burmeister | | | | | Joined: Aug 2011 Posts: 7 New Guy | | New Guy Joined: Aug 2011 Posts: 7 | LONGBOX55, Could you link me to the decoder for that, or tell me what meant what in that serial? Did you see that they used a capital "i" before the 9. I don't mean to pester but you know ,"the more you know"... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | For the code on your engine, it breaks down like this, first letter is the plant code, F being the Flint plant, T would be Tonawanda NY. The next 4 numbers are the Month/Day of assembly, whihc as you may notice, is only a week or so after the block was cast. Last leter is the application. ou mention the "I" that's in the code before the 9, it's meant to be a "1", and is very common to see thm stamped that way. Mine has the same "I" in it's code as well. Something I will mention, as you've found, most decoders do not go past '57, in addition, most of them do not list anything that isn't a Passenger car or Light Truck/Suburban. The Medium/Heavy Duty Trucks and Double Duty/Step Vans tend to get left out. Much of the information can be found on the Heritage site, though. http://www.gmheritagecenter.com/gm-heritage-archive/vehicle-information-kits.html.
Bill Burmeister | | | | | Joined: Aug 2011 Posts: 7 New Guy | | New Guy Joined: Aug 2011 Posts: 7 | LONGBOX55, Thank you very much for your help. I'm trying to go from 0 to competent on this project of mine and the opportunity to learn in an entirely new area of knowledge was one of my main motivators for tackling it. | | | | | Joined: Jan 2013 Posts: 1 Moderated | | Moderated Joined: Jan 2013 Posts: 1 | I have a 1950 Chevy pick-up that I bought non-running and am having similar issues determining what engine size/year is in it. Close to the dipstick is: 0945635F547. On the block ahead of the distributor is: B39-913. And below it is 241-570. The head has the following : CON13 and H104. The valve cover is held on by 4 screws. Any idea on the cu in and year of this motor???? Thanks. Nealo | | |
