1 members (Forty9),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 25 New Guy | | New Guy Joined: Jun 2008 Posts: 25 | geting ready to instal my reground cam,retainer goes on first,round spacer with concave next, what direction does the concave go,? what does it do? thanks art | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | The spacer prevents the timing gear from going onto the cam snout far enough to lock up the gear against the thrust plate. If you measure the spacer with a micrometer or a dial caliper, it should be a few thousandths thicker than the thrust plate. I can't say which way the concave goes, but it really shouldn't matter since the spacer is sandwiched tight between the gear and the cam. Jerry
