| | | Forums66 Topics128,081 Posts1,056,077 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | all the 235's ive played with have the exhaust flange welded to the pipe. all the pipes are short thinned stubs where someone torched it off (amoung other things) while tearing out the engine thereby rendering it useless. with all vendors on the web supplying parts i havent seen any flanges listed. anyone have a line on where to get them. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Are you talking about the front pipe? An exhaust specialist should have it in stock. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | yeah, the one that bolts to the manifold. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Is this what you need? (Towards the bottom of the page) | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | with dial up it takes forever to open that site. i see it only lists to 57 but i dont see why it shouldnt work for a 59. i guess i need to contact them.
thank you. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Also available from JC Whitney regards, Leon | | |
