3 members (homer52, Bill Hanlon, 1 invisible), 140 guests, and 3 robots.
Topics128,026
Posts1,055,408
Members48,422
#61564 06/09/2006 9:11 PM
between the driveshaft to the differential it is leaking. We had put a new seal in it. But still it is leakin. ANy ideas on wat i need to do to fix it. I have no idea? Pictures would help. it is a 64 chevy 1/2 tons. I feel dumb askin this but i am learning as i go on. it is shootin oil onto my tailgate. Please help!!
Stephen
Stovebolt-It is painted
#61565 06/09/2006 10:26 PM
Riding in the Passing Lane
First make shure the pinion brgs. are snug. There should be no up & down play in the yoke. If thats ok pull the yoke & see if the srface the seal rides on is smooth. If not a Speede-sleeve is available to go over it. Pull the seal out. You may have damaged it putting it in or let the spring inside fall out. Install a new sealmakeing shure it is the right size. Put a little RTV on the splines of the yoke & the back of the nut. The nut is self locking. If it doesn,t go on tight get a new one. Don,t over tighten it.
1972 Chevy c10 Cheyenne Super
#61566 06/10/2006 7:02 AM
Thanks bro...will check it out.. again thank you for the help...
