| | | Forums66 Topics128,017 Posts1,055,338 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | hey guys, what amperage toggle switch should I be using to turn on my ignition? I have HEI on my 235 I was going to get a 20amp, but saw that they have 50amp as well. Does it matter? thx | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Why a toggle switch? Most regular ignition switches will carry the current for a HEI without a problem, or if you're concerned about overloading the switch, you could use it to turn on a continuous-duty relay triggered from the "run" position of the switch.
If you choose to use a toggle, a 20 amp should be plenty of capacity. Jerry
